So im in a weird situation and I have a weird plan. i have 3 Bluetti AC200MAX. I purchased 2 of their adapters made to take the output on their expansion battery, and turn it into an XT90 So that you could plug it into the AC200MAX Via the MPPT Input, And Plugged it into the AC200MAX, Which its not made to do. My plan was to be able to pull power out of an AC200MAX And put it into another one, so that I could run everything off one and basically treat The other two as expansion batteries. Well that didn't work, It Gave an error and all the readings for voltage and temp goes blank, So I'm concerned that its basically shutting down (and is incapable of shutting off the port that I'm plugged into) Which would mean that I could overheat or undervolt the Battery and ruin it, So I wont be following that plan anymore.
i just came up with a new plan, Which is to use the 12V 30A DC Output on each one of them, And use Bluettis Adapter to turn them all into an XT90, And then Turn the XT90 into an MC4, So that I could wire all 3 in Series (and then have that go into an XT60), which would safely give me a 36V 30A Output?
Basically The Plan is that I could take that 36V 30A Output, And put it into my anker battery, And I would be able to charge the anker at 36V 20A through its MPPT. So I would basically be treating the 3x Bluettis As Expansion Batteries for the anker, and Theoretically, this should be completely safe since I'm using a Plug on the bluetti that's actually made to output power, And the bluetti will be able to cool itself, shut off when the power is low e.t.c.
So my question, is Does this plan seem stupid? yes I understand that its a Dumb idea, But I already have the batteries, So I just want to double check that my whole plan is safe, And that there isn't a problem having the 3 Outputs go into Series to make 36V?
