Hi All.
Looking for a bit of advise.
Having purchased some second hand kit very cheap, I am cosidering putting some panels on my Garage roof - 3Kw in total, split equally East/West.
I thought i had done a bit of research after seeing an inverter for sale locally and worked out that all Solis S5 inverters over 2.5Kw were duel MPPT. which would have made the wiring easy.
However when I went to collect said inverter, I instantly noted that it had only one pair of MC4 connectors and therefor only the one MPPT. Seeing as the iverter is new and unused, at the price, it was still a no brainer and at a push, I could probably sell it at a profit so its sitting beside me now.
Obviously , I can fit one side of the garage with six panels in series and leave it at that but was looking for advise to see if I can do anything else.
I could fit both sides, all in series but with one half not getting the sun during morning and evening, I assume this would not be very efficient.
What I was wondering was could I wire in 2 strings of 6 panels (one on each slope) and then connect the 2 strings in Parallel? . The problem as I see it with this idea is I would then have a current of around 17amps at about 180v and the inverter max input current is around 14 amps but with voltage up to 600v
My question is would this be an issue with the inverter - would it clip and only use the 14 amps or would it destroy the inverter?
If it was able to accept the current, would it confuse the MPP tracking?
My thinking is with the sun not on both sides except for a short period in the middle of the day, and even then there may be a little shading from a lamp post, with warm panels, I am unlikely to get the full 8.6 amps from both sides.
Any thoughts.
Thanks.
Any thoughts.
Thanks.
