Question about amp hours
Russelljw
I have a 24 v bank…
Six 12v
Each battery is 149 ah
Bank makes 450 ah
I’m changing over to 48v system
I have eight 149ah 12v to use
But it seems I will be getting less amp hours
Only 300.
Does this mean I should leave it alone at 24v bank
Or will the 48v bank be more efficient some how.
If so how?
Thank you so much fellers!
You're getting 300 Ah at 48V! The overall energy is 300Ah times 48V = 14400 Watt-hrs
your 24V system was 450 Ah @ 24V with a energy capacity of 10800 Watt-hrs.
I have a 24 v bank…
Six 12v
Bank makes 450 ah
Only 300.
If so how?
The equation is volts times AH = watt hours
You started by saying you have 6 12v 149ah batteries. then later you said 8. so, I'll assume "8" for the below.
12 (volts) x149(ah) = 1,788 watthours per battery.
8 of those x 1,788 each = 14,304 total
Now, you have the total, regardless of how you wire it.
You can do:
2s4p for 24v.
24v x 149ah = 3576 each, and 4 of those is (4x3576) 14,304
4s2p for 48v
48v x 149ah = 7152 each, and 2 of those is (2x7152) 14,304.
Either way, it's the same amount of energy storage.
As they say, wire in series increases the voltage, but not the AH.
wire in parallel increases the AH but not the voltage.
So all of that to say: the AH looks like it's "half" of the 24v setup, because it is. but it's the same amount of energy :)
