My charging setup is going to be: Alternator -> Renogy 40a Dc to DC converter -> BMS -> 4x 150ah aluminum cells.
I like the idea of using one of the 120A alibaba BMS that others have had success with: https://www.aliexpress.com/item/4000425316662.html?spm=a2g0s.8937460.0.0.4ac82e0es4u6A2 Seems robust for my use case and I love the ability to monitor remotely via bluetooth
My question is how to best handle the situation when batteries are fully charged. My understanding is that continuing to charge when batteries are full creates heat and will degrade battery life. Is it safe to have the bms shut off the charging load when batteries are full? Can it damage the DC-DC charger? if charging is shut off, is discharing also disabled?
thanks!
thanks!
