KeninFresno
- Sep 28, 2021
- 27
Hi,
I have a few questions on the system. If I were to do the distributor-Lynx shunt - Lynx Power in, how would I disconnect power from the batteries to the system if I had to do some maintenance or what ever on the system? I am assuming I would need a resettable breaker or a battery switch for each battery before it lands on the distributor, correct? Same question on the charge controller, assuming a DC breaker of some sort of breaker between the charge controller and the power in?
Final question, I have 4 SOK 100 amp 12 volt batteries and two LiTime 200 amp 12 volt batteries. If I connected both the 200 amps in series and the 4 SOK's in series, I could attach them all to the distributor without any issues correct? That is a the point of a busbar after all is to connect multiple, same voltage batteries. Just need to check my thinking is all.
Thanks!!
Thanks!!
