Texas-Mark
- Aug 4, 2021
- 1,285
This will be a small stand alone system that I won't be adding any more panels to.
I have four 300 watt panels. Due to the voltage limits of my MPPT controller, my only options are 2S2P or 4P.
These are old panels. One of them produces about 16% less (40w) than the other three. I assume that if I connect them in 2S, that the lower producing one will limit the other one in that string. Is that correct?
So my question is, am I better off going 4P or will the higher voltage of the 2S configuration offset some of that 40 watts that I assuming I will lose from a good panel in series? I say 40 watts because these panels will be laying flat. So due to that and their age, I am only getting about 240 watts out of the good ones at noon, and 200 out of the "bad" one.
I'm not that concerned about more cables for 4P as I only have about 10 feet to the controller, but only having 2 sets instead of 4, of course would be better.
