chicagoandy
I am looking for a quiet solution to maintain my 12V 200ah Office Backup, which is setup as a DIY UPS.
I have a
- 200ah 12V battery
- 2200 watt Inverter
- Victron Smart Shunt
- Automatic Transfer switch.
These keep Router/Internet/laptops/microservers up and running for 24hrs. Great!
The SmartShunt and Inverter are always-on, but the other loads only connect when the power fails.
My question is about maintaining the charge on the battery as the Inverter & Shunt are drawing a few watts.
Currently I am using a 40Amp 12V charger. However, when the fan kicks it is is very noisy.
I need the large charger to recharge after an outage. However, the always-on inverter and also the Victron shunt do slowly drain the voltage. As a result the large noisy fan on the charger kicks on every few hours for 20 seconds, which is annoying.
I am thinking of adding a second, much smaller charger, to keep the battery healthy.
Primary Charger: Li Time 12V 40 amp Charger. Noisy fan.
Secondary Charger: Two options.
Has anyone done something similar? Any better solutions for quietly maintaining a DIY UPS battery?
I have a
- 200ah 12V battery
- Victron 12V 7amp charger. Large heatsink, no fan.
- Battery Tender 12V 3 amp Lifepo4 Battery Charger / Maintainer.
