B Bricktop New Member Joined Nov 16, 2023 Messages 48 Location USA Jan 17, 2024 #1 Had this installed by a company and I went up to look at it and seen there are no ends on racking. Its like that on all the racking ends. Attachments IMG_2241.jpeg 324 KB · Views: 25
B BentleyJ Solar Wizard Joined Jan 13, 2022 Messages 2,891 Location Riverside County, CA Jan 17, 2024 #2 Looks like XR10 aluminum rails. Probably easier to just get these end caps at Amazon and install yourself rather than dealing with the sloppy installer. https://www.amazon.com/IronRidge-XR-10-CAP-End-Caps/dp/B07G39X2CJ
B Bricktop New Member Joined Nov 16, 2023 Messages 48 Location USA Jan 17, 2024 #3 I guess I should’ve been clearer in my question. I was concerned nothing is holding the panel down on the ends.
O Osmethne Solar Enthusiast Joined Aug 18, 2023 Messages 92 Location Salt Lake City Jan 18, 2024 #4 You're correct. I'm guessing they forget to order the end standoffs. Definitely something that needs to be corrected lest a strong wind comes through.
J JLD New Member Joined Jan 8, 2023 Messages 23 Location Idaho falls Idaho Jan 20, 2024 #5 Iron Ridge makes an end clamp that goes underneath panel not seen. Put the hack job with saws all cutting of rails looks bad.
