Dear All,
I would like to address an issue with the west-facing panels. During the installation process, an error was made, and the plus connection was placed next to the plus connection instead of being properly spaced. However, considering that the panels are arranged in a landscape orientation, I propose that we explore the possibility of utilizing skip wiring (also known as leapfrog wiring).
Since there is a significant distance between the first and second column of panels, the short length between the negative and negative connections may not be of great significance. Moreover, the distance between the two adjacent panels in the other columns is 1 meter, which is larger than the current spacing we have.
what do you think? Thanks
