JeepHammer
Solar Wizard
- Nov 15, 2019
- 1,149
Can a 240vAC(13A UK plug supply) circuit be switched using a continuous duty NO contactor with a 12vdc 0.8A 'control circuit' and rated at say 400A on the load side.
If not, why not exactly? If it is simply a switch and the DC control side is a seperate circuit from the AC load side, why do i keep hearing that it is a problem? Surely a switch rated to handle 400A dc would easily handle 13A ac for example. What is it about AC that would be an issue for the contact?
240vac coil, 40 Amps..., Use two if you want to double amperage.
https://www.automationdirect.com/ad...n-style,_40a_(ad-pr40_series)/ad-pr40-2c-240a
Relays draw about 3 amps, but if nighttime power is free...
relay fails on grid power
I would use a timer to run house and charge batteries at nigh,
Disconnect from grid in daytime and use battery power in the day.
Timer before Disconnect/Transfer switch.
Timer turns grid power on to the inverter so batteries can charge at nigh,
A second to transfer transfer the house (Load) between batteries and grid day/night.
230 volt timers are all over the surplus sites for cheap.
