chrisski
Solar Boondocker
- Aug 14, 2020
- 5,198
I will be adding some removable panels to the side of the RV. These will be removed whenever I'm driving and will only be set up once parked.
These will be South Facing panels, with the intent of when I use air conditioning in the fall and spring when the sun is lower to the ground, this will give me 150 - 200 watts extra battery charging power. Now, my 2550 watts of panels covers running the AC at those times + or - 100 watts, so this extra should be enough for what I want.
•50 LBS Total Weight
•Panel Weight
43 LBS
•Strut Weight
5 LBS
•Threaded Nut Inserts
•Spring Nuts
•Brackets to secure panels to strut will be leftover from a project.
•Panel Weight
43 LBS
•Strut Weight
5 LBS
•Spring Nuts
