Total newbie here, I bought the Renogy 4x 100w kit with 40a MPPT kit for RV before doing actual proper research, wasn't aware how bad these products are.
I had the local RV shop do the install, they set it up to code so I feel like it was installed properly, they installed the 150 aH lifepo battery inside, along with my 2500w pure sin inverter, put in the breaker, etc.
For a week it worked perfectly. The trailer is parked in the sun and was keeping the battery fully charged to 14.5V
Then we had a couple days of rain, then more sun and I came back to the trailer today so do some test and the battery was dead.
I trickled charged the battery back up to 13v so the MPPT controller would come back to life but it wasn't taking a charge from the panels.
I started testing a bunch of different things and then went on the roof, I saw that the positive lead has a MC4 10amp fuse so I took it off and saw that the fuse was dead. I swapped it with another 10A MC4 fused connector that I have for my portable 100w renogy and everything came back to life.
I also checked the MPPT controller setting for LI battery and saw that the default settings are not good, so I updated them per the guide on one of the thread here.
Now the question is, what could have blown this 10a fuse ? Should I try a 30amp inline fuse instead ? It never got above 25C so I doubt it was the heat.
