2Big2B
Free Wheeler
=============================Seems like a pretty decent deal.
If you can afford the price now, I'd prefer to not risk it going up.
It is not uncommon to see 200W panels @ 12V. All appear to be 12V panels, so you would need two in series.
What I can't find is what they way, or their physical size. I would count on at least 35# each. This may be a lot to manage.
What do you want to spend? Do you want the awesomeness of Victron? You wouldn't need more than a 100/20 or similar. You could get away with a PWM as well, and those are dirt cheap.
Personally, given your physical limitations, I would look at 3X 130W flexibles. They claim 4.4 lb, and that's 390W for about the same $ as 2X 200W. 3S would require a 100V MPPT though. A Victron 100/20 with bluetooth is $90.
Specs: "ECO-WORTHY 200 Watt Bifacial Solar Panel Mono PV 12V"
Brand JJN
Material Monocrystalline Silicon
Product Dimensions 30.3"L x 1.4"W x 53.7"H
Item Weight 25 Pounds
Efficiency 200W
I could probably handle a couple of these.
Which 3X 130W flexibles are you suggesting that I could get for the same cost? These?
With the 20% off with code HOT20DEALS, they are $190 for three.
![12V Portable Flexible Solar Panel Kit RV Camping Off-G_ - www.ebay.com.png 12V Portable Flexible Solar Panel Kit RV Camping Off-G_ - www.ebay.com.png](https://diysolarforum.com/data/attachments/219/219540-e362b8c564431008ffc13b54b71540f3.jpg)
My impression from listening to Will Prowse about flex panels in general is, they all suck. Very exaggerated claims of efficiency and outputs. It looks like they are very unpopular on this forum. I do like their light weight though. I have seen you give the opposite advice to a guy with an RV along the same lines as what everyone else has been saying. But perhaps in my case though, because of how I want to use them, it is qualified advice. So, Maybe. I will mull on it.
As for my budget, a $300 indulgence for something I might never use is about my max.
Let me further investigate if these flex panels would fit the bill.
I also need to know more about the charge controller best suited for this...
This one (open box!) ?
![Open Box Victron BlueSolar MPPT 100_15 Charge Controller SCC010015200_ - www.ebay.com.png Open Box Victron BlueSolar MPPT 100_15 Charge Controller SCC010015200_ - www.ebay.com.png](https://diysolarforum.com/data/attachments/219/219563-74d5a55d4190f9ece00d690be0e12f45.jpg)
Putting this all in the Cart, it would cost:
Items (4)$292.91ShippingFreeDiscount-$2.40Tax*The state of Virginia requires eBay to collect sales tax and applicable fees from buyers. eBay will pay the collected tax to the tax authority.$17.43Gift cards, coupons-$47.51
Order total: $260.43
That could work... But I probably still need some connectors and such?=======================================================
Thank you Sunshine!
