Just bought a few of these and every morning they're sitting there in E01 and presumably in what Renogy calls "low over-discharge protection". Even with the sun up high, it just stays there not charging. My 24V system has dropped by the time I get to it to about 21V, non-load. I'm guessing overnight it gets low-ish, like 24V and when the pump comes on, it drops the voltage enough that the charge controller drops out and then just never comes back on again.
I have a Victron voltage cutoff set to 20V and it never gets low enough to engage that. I've used an ePever charger before and while it would go low overnight, it would still be available to charge in the morning and all was well.
Is there any way to disable this mode, or set the LV cutoff low enough that it doesn't engage and then effectively turn itself into a brick? This is not a good feature.
