Dustin Henderson
- Nov 2, 2022
- 17
Hello all.
I am not near the SCC / Solar install right now but want to gather some instructions/guidelines so I am most prepared when I head back up to the travel trailer it is installed on next time.
I have successfully installed and wired my phase one / proof of concept: 100 W panel, PV disconnect, Rover 40 with BT-1, Renogy Shunt, Battery disconnect, and associated fuses. Battery is a Chinese LiFePO4 100Ah which I have had a couple years and works wonderful.
I verified a charge was being received by the SCC from the panel, and the battery was charging per the default Li profile in the SCC. Once I made that simple verification, I had to leave so I disconnected the system as is my typical storage process.
When I return, I will add the second panel and for now run 2x100W in series. Future will be 4x100 in 2S2P.
But the questions I have first are around the SCC and shunt configurations.
1) From reading, it seems common for people to immediately start using a USR charge profile instead of the default Li profile from the Rover. Should I not even attempt to use the default profile and immediately go to as USR profile? A common complaint is that the Rover seems to under report the voltage between itself and the battery. Is this generally accepted as true? Charge Voltage for this battery is listed as 14.4. Standby Voltage is listed as 13.8. There is a “Voltage Window” specification listed as 9.2 – 14.6V. Those charge voltage numbers actually seem a little higher than I typically see.
2) The location of the SCC is a little inconvenient to read the display, and I assume the BT app is referred regardless. Any problems with the app or anything I should know beforehand?
3) I assume that every time I disconnect the PV and then Battery (for long term storage for example) any defined settings (including battery type) will be lost. True? A bit lame if so. Does entering them in the app restore them to the SCC automatically upon power up?
4) I understand I need to ensure the battery is fully charged before configuring the shunt for capacity monitoring. The catch-22 here is how do you know “full is full” without a shunt? If we accept the SCC as unreliable in this regard, and if we accept using a Voltage meter is imperfect as well, It seems all we can do is best effort if not using some external and trusted charger (which I will not bother with). I assume this is a 98% accurate is close enough, and can certainly live with that but wanted to verify that charging to full according to the SCC and my multimeter was as good as it gets.
Hope the questions make sense. It is slightly inconvenient to do a project like this “remotely”, but so far everything has worked exactly as expected.
