Renogy Rover 60A Modbus Register Map
fincol
Boone
Using the Renogy Rover with the BT-1 add-on, and trying to find ways to data log past the BT-1 (since it can't be used for logging). Planning to hook up an arduino board with an SD card to log, but need the ModBus register map for the MPPT before I can do that. I haven't been able to find the map so far, has anyone had any luck with this?
See the attachments. I use these for my Renogy Wanderer.
In addition you will find a number of Renogy projects on https://github.com/
  • ROVER MODBUS.pdf
  • RegisterAddresses.cs.txt
