FreeRangeMira
I’ve purchased a Powerurus 12v 100ah battery based in Will’s recommendation. The first battery was defective and Powerurus (RowPow) support was great. They had me try a few things but determined the battery needed to be replaced and quickly sent me a new battery. The original battery had a huge cell imbalance between 2 of the cells according to the bt app. So with nothing to loose I opened up the battery. I measure the voltage at the balance leads and they are all within a few millivolts. Based on this, I assume the BMS is defective. I hate to throw away 4 perfectly good cells. Any recommendations for a BMS to replace the original in the battery? Anything I need to be aware of when replacing the existing BMS? I assume I want a 4s 100a BMS (that is what the original is). Any advice would be greatly appreciated.
