i helping a friend to retrofit a reach truck from lead acid to lifepo. currently it is using 48v 360ah (24s) flooded lead acid battery, nothing in between from the battery to reach truck just a anderson connector. My plan is change it with 32 cell of lishen 202ah 16s2p, and the BMS is 250a continuous rating (relay type), my question is should i add a fuse on it(reach truck have it own fuse in controller)? if fuse is needed, it is recommend to add it before BMS or after BMS?
And is the battery need any compression on it? my planning was build 4 12volt module with little compression pressure, the reason for building 12v module is easy to lift up and easy to compress than whole big battery pack.
Equipment list:
lishen 202ah battery x 32
16s 250a smart BMS (relay type)
48v lifepo charger 100a
300a DC isolator
aili battery monitor
current plan:
battery > aili battery shunt > BMS > DC isolator
Any input from you guys is appreciate and sorry for my bad english.
Equipment list:
300a DC isolator
current plan:
