There are clips to secure PV wires to PV panel frames.
I will run EMT conduit up exterior of house, around the eaves (which are less than 1'), and secure it to standoffs (similar to Q-dog's rail mounts, except those use L-feet over flashing while mine will have cylindrical standoffs through flashing and L-feet on top of those.
At the end of the conduit I'll mount a junction box.
Jumping between array sections on different faces of roof, I'll use a bent length of conduit. Plastic nuts over the ends.
There is a spec on how long a PV wire between supports, and how close conduit is to roof (1"?)
Of course, include a ground bonding wire in your conduit, bond the rails and the panels. Some panel mounting methods provide connection to rails and use them as ground conductors.
