Kuma
Installing Panels that are aluminum frames and using Ironridge rails. The house roof edge is very low, 7'6" I can reach up and touch it. The panels will be 16"~18" from roof edge, with the rails about 6"-10" inches above that, making it very easy to look up at the rails which are directly above the front door. Im thinking about installing black rails and fasteners to limit the amount of shiny aluminum when looking up from the ground. Ironridge sells a "contour" skirt that attaches to the panel frames but it is expensive
I could not find pics of mixing rail and panel colors. Would black rails make a difference after installation? Black fasteners also or should fasteners match panel frames?
