Do 250amp BMS exist? I'm struggling to find a decent 140amp.
looking at the victron orion 12/12 30 that you recommend, I see that it is isolated and not isolated.
can you tell me the difference for my use.
The isolated is used when you need to keep your vehicle electrical system, and 'house' battery system separate, and you will not be grounding your house battery system. The non-isolated will be used if both sides of your system are grounded.
Can you suggest a source that provides more information? I would like to get a better understanding of the isolation issues.
I read those threads a while back and just reread them. They make a little more sense to me. They also worry me. The question I end up asking myself is, "Should I be isolating my two systems?" They're both 12v and all they'll share in common is the negative ground. Since I don't plan to charge/draw between the two, I don't think I need to worry about it.
But honestly, I still don't deeply understand the implications of one method or another.
then for the installation of my van without grounding I must mount the insulated one.
Is that so?
If you get the isolated and don't need it then you have just paid a bit more.I read those threads a while back and just reread them. They make a little more sense to me. They also worry me. The question I end up asking myself is, "Should I be isolating my two systems?" They're both 12v and all they'll share in common is the negative ground. Since I don't plan to charge/draw between the two, I don't think I need to worry about it.
