ericfx1984
- Oct 10, 2021
- 741
So my current lead acid battery is installed in a hatch that is underneath the fifth wheel hitch
This is super convenient as I'm able to have my inverter and battery Bank within 2 ft of each other not only does it help with the cost wire, but it definitely helps out with loss
But that hatch is exposed to the outside air and as such will likely experience freezing temperatures so it's kind of a no-go
However only a couple feet away from there is the foot of the queen size bed which has a cavity underneath it about 18 in tall and otherwise the size of the queen size bed less a few inches
Now this is inside the heated and cooled area but doesn't have any ventilation to connect it to the heated and cooled area so what I was thinking about doing was adding a couple vents and that would allow me to locate the battery there 5 foot or so of cabling is not really a big deal
The other option would be to locate the batteries in the closet of the main bedroom.. but these are on either side of the nose which works out to about 13 ft of cabling and takes away valuable closet space
Of course another option is to move them in the storage underbelly.. the big problem I see with this is that the storage underbelly isn't really heated but it does have two vents and a t running through there so it should stay above freezing one would think
And yet another option, which I really would rather not do would be to locate the batteries in one closet and then on the other side of the bed where the other closet is to locate the inverter this would make the cabling probably somewhere between 5 and 8 ft...
I'm leaning more to locating underneath the bed as it is around 5 to 8 ft of cabling and I don't have to move the inverter and rewire anything on the RV
But I guess my real question is if I have a bed where the bottom of the frame is closed off and I add vents to either side will the battery stay cool enough? Or will I need to do some type of fan that kicks on if it gets too hot?
