Hi guys! New to the forum but very familiar with Will's videos. Anyway, I live in Colorado in my RV full time, after dealing with this shitty lead acid house batteries that wont run my furnaces through the night, I decided lithium is the way to go. I scored 16x LYP260AHA cells for a great deal. Currently my RV has 140amp alternator, 2x 12v deep cycles, a starter battery, a 55 amp progressive dynamics converter, and a 6kw genny. My plan currently is to put the 16 cells in a 4s4p configuration under the bed in the back. It will have a daly BMS on it. I also ordered a 70amp non-isolated DC-DC charger. I would like to be able to charge the Lifepo4's from the alternator as well as the generator. Here are my issues. The RV is 33' long, In order to tap into the existing 12v system, i need to run wire from the existing house battery bay to the bed, Since the largest loads will be under 30 amps total, I dont think sending power will be an issue. Here is where things get confusing for me. I want to add the DC DC charger to the bay where the house batterys were, since the output is 70 amps, I will run appropriately sized wire back to the bank. My original thought was to leave the lead acid batteries in the bay and hook the DC-DC charger to them, but now I think I will eliminate them. My first question is, will the 55amp power converter run the 70amp DC-DC charger ok or will it cause issues? Now, if the power converter needs to be larger, it seems to me that just getting 100amp power supply and feeding it to the DC-DC charger would be more cost effective than getting a larger power converter (that has charge stages etc..) as the DC-DC charger will control the charge curve. Am I overlooking anything?
Thanks.
Thanks.
