SomebodyInGNV
- Jun 3, 2020
- 182
Hello. I'm a newbie and am accumulating material for a solar system on my travel trailer. I have an EPEver Triron 4215N MPPT controller, a QWork battery monitor, a cable entry plate with integrated MC4 connectors and 1' stub of 10AWG wire, plenty of 10AWG wire on a roll, and about 15' of 8AWG wire. None of the wire is UV-rated. I'll get appropriate cable, bus bars, breakers, fuses and other hardware as the need arises. I own a crimping tool.
My main goal right now is obtaining panels. The unobstructed and unshaded area on the roof is about 10' x 8'. Panels could be a little longer but the ends would be getting into a area where they might be shaded. They will be mounted flat and we frequently camp in the shade, so it seems like I should over-panel? I'd like at least 12" and prefer 18" of walk space down the middle of the roof. I'd like to install all panels once rather than install some now and expand later. I prefer panels with MC4 connectors so I don't have to do anything except attach them to the roof and plug them in.
I'm here looking for recommendations for sources of panels, suggestions as to specific panels to buy, and the recommended series/parallel configuration. Local solar installers aren't interested in selling to me. I have no qualms about recycled panels from reputable vendors. I live in Florida, so shipping from out west may be prohibitive. Specs for the controller are below. Further details are in link above.
Rated Charge Current
40A
Rated Charge Power
520W/12V
Max. PV Array Power
1560W/12V
Max. PV open circuit voltage
92V
My initial setup will be to maintain my current 2 x 6V GC2 FLA batteries with 215AH total capacity. I don't have an inverter and rely on the OEM (WFCO 8955) converter/charger, which is not Li-compatible, when on shore power. My power consumption is modest. We have a couple of CPAPs without humidifiers, LED lighting, 12V stereo, one Maxx-Air vent fan, and rarely use the furnace. We do want to be able to use the furnace on travels out west, though. We also have 12V chargers for a laptop, a tablet and a couple of phones. The refrigerator is propane with a 12V control panel.
After the controller and panels are in place and working, my future setup will include a LiFePO4 battery, a compatible converter/charger, a pure sine wave inverter and an auto-transfer switch to power a single 15A circuit. We won't use the latter for the microwave, AC or any heat-producing appliance. Most likely, it would be for a couple of hours of TV at night, and maybe a wall or desk fan. If I ever have to replace the refrigerator I'd get a 12VDC compressor model and increase the Li battery capacity if indicated.
Thanks in advance for sharing your expertise.
40A
Rated Charge Power
520W/12V
Max. PV Array Power
1560W/12V
92V
