Screw on solar panel brush for snow?
rhino
Solar Wizard
Minnesota
Does someone have recommendation for a brush that can screw on to one of those telescoping poles with the "standard" screw on end? I have this pole. They have a scrub brush that is 11" wide which is pretty narrow and didn't know if someone had a better recommendation. There has been a LOT of days this winter where ice accumulated on the panels overnight and then snow. You can't use a normal squeegee type head to get the snow off well because the ice would so rough a lot of snow would be left on the panels still. A brush would work much better if anyone has recommendation.
Push broom from any hardware store
I need the head only and has to be somewhat lightweight. Some of my ground mounts are higher than 15ft high when fully tilted for winter so there is no way a push broom is going to reach that :)
Check out the Snow Brum. It's not going to scrape ice off your panels but it will break through light ice on on top of the snow. It does a good job clearing snow from panels.
