Seeking a lifepo4 charger/discharge test for 8S (24V) batteries.
matt2006
DIY Solar since 2016
North California
Hello my fellow smart people.
I buy these K2B24V10EB from a ewaste recycler; and I test them.
I have been using the iCharger 3010B as they can do up to 10S AND they can do regenerative discharge which means I'm saving all that energy that is coming back out of the batteries.
The problem is I have to have a laptop to display and every few months the USB connection to COM and the charger stops working for whatever reason.
I cannot buy more of these chargers as they're no longer manufactured.
SO; seeking an alternative charger/discharger that meets these requirements:
1. Can Charge/discharge 8S minimum lifepo4
2. Will display mAh on its screen and not go blank if the battery disconnects itself from low voltage cutoff in the BMS
IDEAL but not required:
3. REGENERATIVE discharging
4 Banks would be cool as well
Clones of icharger 3010B:
Charsoon Antimatter
HOTA Thunder
Turnigy 1000W
Dual channel charger nearly the same as 2X 3010B (30A, 8S):
An absolute monster, more power than 2X 3010B (You can even get 70A by pairing the two channels together):
Other 8S/regenerative:
Thanks a bunch!
I have ISDT Q8 but it doesn't read voltage right; i do a 3a discharge and it locks in at 0.4A which is not acceptable.
I bought the 4010 duo but may return and just go with 308 duo to save costs.
Do you know if the 4010 has better features that make it worth it?
If only the input went up higher than 50v; a littler higher and you could use a 48v lifepo4 bank to power it.
Thanks a bunch!
It's just higher limits (power, 40A/channel) and the ability to go to 70A dual channel on one battery.
Here's my new test bench with a 4010Duo and 308Duo
NOW I have 4 of these iCharger 3010b I don't need;
is anyone interested to buy? Retail was $100 each
