missingegg
- Nov 6, 2022
- 26
Hey all, I'm preparing to select solar panels for a hot desert climate with a pretty consistent daytime air temperature of 40C. I see that a lot of vendors are now making all black panels, and I'm trying to understand how that negatively impacts the power production of the panel when it's hot. I understand the temperature coefficient that can be found in a panel's spec sheet. But I'm a bit confused about how to evaluate how much hotter a panel might be because it's all black. Concretely, would I be better off with something like an LG NeON R that has obvious silver stripes between the cells, versus a Rec Alpha Pure that's all black? I assume that a black panel will be hotter, but I have no idea how much hotter. Is the NMOT stat the way to evaluate that? I see that the Rec Alpha Pure has a NMOT of 44C, which is exactly the same as the NeON R at 44C. Does that mean that I'd expect these two panels to reach essentially the same operating temperature, or is this not the right way to evaluate a panel's spec sheet? For complete context: I'm space constrained, so I cannot compensate for lower panel efficiency by just buying more panels.
Spec sheets for the two panels I'm talking about:
