Hello everyone, I'm struggling to have my Voltronic Axper Max 8000W (EU) to communicate (RS485) with my new battery pack purchased from Basen Green, so I'm trying to collect info around, as I'm not sure if the guilty here is the BMS, the Inverter or anything in the middle.
The battery is this one: https://www.basengreenshop.com/48v-...lifepo4-battery-pack-for-solar-energy-storage
By guessing and with the help of other people, I tried to determine which kind of BMS it uses (to collect specific info about my issue), and I guess it's using a SEPLOS 3.0 "Type B": https://www.seplos.com/seplos-24v-4...tery-management-system-2a-balancer-board.html
The issue I'm having is no matter what, I can't make it communicate with the inverter by setting the BMS 485 port to "Voltronic" and the inverter to "LiB" as per instructions. I get the Error 61 after few minutes. The pins are connected as follow: pin1 battery (CAN B) to pin3 inverter; and pin2 battery (CAN A) to pin5 inverter; I've also tried to connect the GND but makes no difference.
The Inverter reseller suggested to update the MCU firmware to 12.21, so I did, but no avail, the problem still.
I suspect there's a compatibility issue with the LiB protocol, as the connections appears to be fine. Does anyone have experience with this BMS and Voltronic inverters, or have any idea of what else I can try? Thanks!
