I had a similar problem. I turned off shortcut protection in the Solar monitor app and then bms exploded.
One FET burned out.. I replaced the FET and now it works fine. I would not recommend repeating my procedure because the PCB on the BMS could have burned. Maybe, you can try to replace the MOSFET before.
