Series/Parallel wiring (24V) and wire sizing
31ectr0nicb0b
Boston
The following is my build thread in case anyone wants to see more detail, not that there is much just starting, pretty much a noob.
My main questions are:
  • Given my setup, 24V battery bank (400Ah 24V), FlexPower One, VFXR3524 inverter and FM 80 charge controller, does this wiring plan for the batteries look ok? I have seen wiring diagrams where the parallel wiring is created first between [2]12V batteries and then series wiring, according to my plan, I am doing the opposite. Any pros cons?
    • I am thinking this way depicted below would be the best way in terms of using least amount of wire.
  • Where do I run the main positive (+) and negative (-) to the FlexPower One? Off the right side of the image below?
    • And what gauge wire should these mains be?
  • I am planning on using 1/0 wire for all of the connections. Adequate?
Looks fine.
No.
Your main leads need to draw from opposite ends. Main (-) on one end and the main (+) on the other end.
Sized for the current they need to transfer.
Interconnects and main leads need to be the same size.
Is that sufficient to handle the needed current?
Oops, forgot to give those details, so VFXR3524 inverter is 3500W output and it is a 24V battery system, 3500/24 is ~145A.
The Southwire voltage drop app on my phone for 10' run (I probably wont have more than a 5' main (+-) run from batteries to inverter) for 24V and 3% voltage drop and 150A is 1/0 AWG.
Does the image above look good now for the main +,- at opposite ends of the battery bank?
3500W/25.6V/.85 = 161A
85% efficient. Yes, your inverter has a higher efficiency spec than 85%, but that's at about 30% rated power. It decreases as power output increases. 85% is a conservative
1/0 would yield a 1.24% voltage drop. You would need to get 90°C or better rated cable. 60 or 75°C cable does not have sufficient rating to handle 161A.
You have a lot of connections. Make sure all connections are properly torqued.
Yes.
