I am looking for an emergency back up system to help with periodic outages from wildfires and earthquakes (th joy of California).
I'm considering the Bluetti AC50CS or the EB150.
I'm not sure if the EB150 is overkill given that I only need to be able to run the igniter on a gas powered water heater, a 12V portable camping fridge, the igniter on a gas powered furnace, and recharge cells phones and laptops (not at the same time). If I want to try to keep the freezer going, I assume I'll need the large capacity battery.
I was also thinking of using a 100W panel-I'm gravitating toward a Rockpals SP003 (for the portability) or an HQST panel (for the price).
Does this make sense? Any suggestions?
Also, if I'm storing a lithium battery for an extended period time between uses, what level of charge should be used?
Thanks
Thanks
