Goboatingnow
- Jul 3, 2022
- 1,325
Switched caoa
Active top balances are typically switched capacitor, the capacitor is switched to the high voltage cell , th3 cap is charged and then switched to the lower voltage cell ( or cells ) where it discharges into that cell.
Really balancing has nothing to do with a BMS. It’s really a charge function but as it needs cell connections it’s sometimes integrated into the BMS as a result. Personally I prefer separate balancersAFAIK, typical passive balancers operate on a differential voltage principle i.e. if Cell A is higher than Cell B, bleed some current off to Resister A. If all cells charge equally, no balancing occurs. I believe active balances work in a similar way but instead of bleeding current off to a resister, they instead somehow 're-route' the current to cells that are 'differentially' lower.
For the most part, these differential voltages only occur at the charge extremes i.e. nearly fully charged or nearly fully discharged but I don't think there is a setting i.e. start balancing at 14V.
