Hi
I'm planning a small campervan setup using a 200Ah battery powered by just one 200W solar panel and just need to settle on the choice of Victron MPPT charge controller.
My question is if I want to get the most amps back into my battery should I go for the larger capacity Victron brand MPPT 100/30 charger controller in the following 2 choices below if my solar panel max power current Imp = 9.76A ?? or is the 9.76A the most that I will be able to put back in which case the 75 / 15 unit would suffice?
1. Victron charge controller MPPT 75 /15 rated at 15A
2. Victron charge controller MPPT 100/30 rated at 30A
Thanks in advance
Choose the 100/30 Smart Blue tooth Version ( Always over size with expansion Capability.)
Victron is a solid choice with warranty.
These units come with removable fuses. Scan code and down load the app on face plate of unit.
Set battery type and parameters.
Typical PV wires are 10 AWG others are 8 AWG can handle bigger arrays.
Aims 100/30
The wire from charge controller to battery accepts 6 AWG ( do not go smaller ) undersized wires = resistors thus heat = power loss.
200 watt PV Insert a 15A DC breaker on PV Hot lead from CHARGE CONTROLLER to BATTERY. Should handle Higher PV voltage cold conditions
Battery to Inverter copper wire install (inverter amp draw matters) wire gauge reference.
Use size: 2awg 130amp 1/0awg 170amp or 2/0awg 195amp or 3/0awg 225amp or 4/0awg 260amp Cable for DC application.
Use basic Ohms law math for Amp divided by volts = watts for the inverter size used apply wire gauge here.
Solder all wire unless a cold compression Crimp type is fitted ( turning strands into blocks conformed to lugs) to ensure full wire contact
or use the best profession crimping method available to you to avoid power loss and resistance.
Battery to inverter fusing is suggested to be 125% of total inverter amp draw. This is complex due to inverter quality.
We NEVER Use / go over 75% of the inverters rating in power draw on Low Frequency Pure sine wave types. Longevity issue.
My wife insist on using the microwave while the Air Fryer is chugging away. ( Eye twitch ) Granted my systems a beast but still...
Modified sine / High frequency inverters terrify me ( that is all to say here. )
I cannot make any suggestions here when dealing with them.
Normally made cheap / affordable and cannot make 75% or even 50% of their rating continuous duty in my experience.
Insert AD here!!! ( " Quanjo professional make you feel good happy life 4000w modified sine wave run whole house!)<- no, just no.
Must use some type of copper wire corrosion inhibitor on all terminals ( Please step up advanced solar installers to help me here.)
I use dielectric grease because I'm poor. There are better options out there. I'm at least trying here.
Please correct me if anything is wrong of off. Hope this helps. You got this!
Hi
Thanks in a
