Ok Im ready to add solar to my rv!!
My goals:
1. I want to be able to run a 1800w ac continuous during the day. (off at night)
2. Have the ability to (for a limited time) run a water heater, the ac, and a hot plate at the same time(5-6kw)
3. Plug into the grid without having to use manual switches
My constraints of the aluminum roof of the rv is 8 foot by 18 foot (flat roof no obstructions).
So I have determined for the most output possible I would like 4 panels of greater than 500w. (45x90 inch aprox)
There are several manufacturers with that large wattage.
I see that renology has a 550w panel for about $500
Also hyperion bifacial 540w from renvu.com for $295 a panel
I was thinking of using (16) 200A lifepo4 lithium cells from aliexpress for a 9600w 48v system. (I already have the cells.)
I want to be able to hook up the rv to the grid at the campground at the same time the panel charges the batteries.
I was looking at hybrid solar controllers such as the eg4: https://signaturesolar.com/eg4-8kw-hybrid-inverter-8000w-48v
However on YT, videos of the fans for these types of inverters were very loud! I will be sleeping next to the inverter.
So I looked into fanless inverters and found this solis inverter:
So I guess my question is would this system be compatible and will it satisfy my goals?
I will normally be plugged into the grid at camp sites and only need the solar to be used as a battery back up for when I am traveling.
Also, is there a better inverter than the solis for my needs?
My goals:
Solis Inverters RHI-1P10K-HVES-5G-RSS - Inverter Supply
Shop for Solis Inverters RHI-1P10K-HVES-5G-RSS at Inverter Supply for best prices online. Solis Inverters RHI-1P10K-HVES-5G-RSS, Solis Inverters, RHI-1P10K-HVES-5G-RSS, Hybrid Inverter 10kw 5G Single Phase Dual MPPT. US Version with tigo transmitter with 10 years warranty, Solis 5G Single Phase
www.invertersupply.com
