foilandwater
Hi, I'm a kite surfer and as a hobby I build weather stations that help us see the wind and ocean conditions at different spots. You can see my simple website here incase you're curious. The weather stations I build typically consists of 4 devices, I've listed their power requirements below. Important to note that a) all this equipment needs to run 24/7 and b) it will be installed at a remote site about 2 hours from my house so it should require little to no maintenance.
I have a requirement to install a camera in a location without any power, so I'm looking to build a solar rig that can power the above. My understanding is basic, and I live in the United Arab Emirates where it is sunny 99% of the time.
I have been given a quotation from a local solar shop for the following, does this sound reasonable?
Thanks,
Sean.
- Raspberry pi - 5V / 2.5A
- Base station for weather sensor - 5V / 1A
- TP-link SIM card router - 9V / 0.85A
- Hikvision IP camera - 12V / 0.4A
- 3 x 170W panels
- Gel battery 200 AH
- Solar controller 60A
- Does the above combination of equipment sound under specified, over specified or about right?
- I would prefer to use MPPT over PWM
- It would be ideal to monitor the solar controller remotely via the cloud / app for iPhone
- I could use something like this to power the 2 x 5V devices. I will need a similar device for the 9V router.
- Does it need to be a gel battery? Can I just buy a regular car battery?
Thanks,
Sean.
