Visionquest
I'm going to build a 280aH Lifepo4 battery using sourced cells and BMS. Remaining concern is cranking power for the ONAN5500 genny in my RV. The cells can do 2C (560amps) for 30 seconds which exceeds the expected 350amp max cranking amps that the 5500 might want.
Anyone have experience with a 12v BMS that can do 350amps for 30 seconds? Alternatively, does anyone have experience putting two BMS's in parallel to pull more amps from a single battery? If I use 200amp BMS's it would theoretically support 400amps cranking power. My thought is that two BMS's is much cheaper than building a second battery, plus I have space constraints.
Thanks in advance.
Thanks in advance.
