Trailpower
Hello everyone. I am installing a small 'off-grid' powerstation-based system that will run independently from my 13kw grid-tied system. I could use some advice on safely running PV power into my mechanical room where my 4kw Anker 767 and critical loads panel are parked.
Scenario:
Scenario:
- I have a pair of 480w panels on a small ground rack. I will be running them in parallel due to the 60V limit of the Anker 767.
- I am planning to mount a combiner box on the rack, and from there, run a 6AWG line in buried conduit to the house.
- Is the welding lead/battery cable sold by WindyNation and Temco good for buried conduit? If not, whats the most cost-effective solution?
- Do I need a shutoff switch on the house exterior, separate from the disconnect in the combiner box on the array? They are about 35 ft apart.
- What is the correct way to pass the 6AWG line from the exterior through the interior sheetrock in my mechanical room?
- What is the correct way to run the 6AWG along the wall of my mechanical room, and how to terminate and transition to XT6?
- Is it appropriate to install a grounding rod next the two panels? Or do I need to run a ground back to the house?
