ShirBlackspots
I am slowly setting up a small scale solar system. I built (that I still need to finish putting on the tin strips) a 13S10P battery using BAK 5000mAh 5A continuous, 15A max batteries, bought mostly from https://liionwholesale.com/ - That was $727 just in batteries (because I bought them over 2 years)
I bought the following BMS: https://www.amazon.com/dp/B0CW5Q8HZ4 - 100 Balance 60A Active Balance BMS for $76+tax (I'll likely get a JK BMS if this one doesn't work well)
I bought the following Inverter: https://www.amazon.com/dp/B082XTMKKB - A 2500W Reliable Electric Pure Sine Wave Inverter for $274 + tax (Texas)
I bought the following MPPT: https://www.amazon.com/dp/B09KF94CJH - Victron 150V/45A MPPT for $218 + tax
Also bought the Victron VE.Direct to USB cable: https://www.amazon.com/dp/B01LZ6WTLW for $28 + tax
So, far I've spent about $1470 to get this far.
I would like at least 8 of these panels or similar Jinko 385W Solar Panel 144 Cells JKM385M-72HBL-V (if not available by the time I have money to buy them), which will cost $1050
With the 150V/45A MPPT, the panels would be set up in a 2S4P setup.
My eventual full scale solar panel system I want would have all Victron equipment, at least 8kW of solar, 32kWh of battery (Gobel power DIY kits, probably) and 24kW of inverters. An additional 12-14, 385W panels similar to the panels I would buy for the initial system
For example, the full system I would want, bought from Current Connected would be the following:
10kVA 120/240V Residential Off-Grid Power System - $5073
Victron MPPT RS 450V/100A SmartSolar Charge Controller - $1231 -- These can handle 7.2kW of solar on each tracker, for a total of 14.4kW
Victron 48V MultiPlus-II 5kVA 120V Inverter - $1711 -- two additional ones, for a total of 20kW of power
(Total of $11,250 from Current Connected)
An additional 14 of the Jinko 385W panels (if still available, in 7S2P config), with the option on adding another panels to the other tracker, which would cost $1840
From Apexium (for a total of 32kWh of battery power) shipped directly from China ($3600)
Apexium Stackable 48V DIY 280/304 kits with 200A JK BMS - $429.99 each, 2 total (these are $660 each for US stock)
EVE 280Ah LiFePO4 EV grade cells - $59.99 each, 32 total (these are $90 each for US stock)
and I would want two (it includes a 200A JK Inverter type BMS, which can communicate with Victron equipment)
One would cost $1390 + $400 for shipping and fees, so $1790 (vs $2100 for US stock)
This full sized system would cost me around $18,000
