Take a device like this: the Renogy Rego.
It features the ability to hook up an optional Smart Alternator cable if the vehcile into which you are installing this product has just such an altenator.
And on page 54 of the linked manual, the logic the device will use to have the house battery charge the starter battery differs based upon whether you have this Smart alternator cable (i.e. you have a Smart Alternator) connected or not.
Here's my question. With the vehicle's engine off how does the device, even with the Smart Alternator cable connected, know you that you have a smart alternator if (I presume) no current is being carried on this cable with the engine off?
Is there something about merely plugging in this Smart Alternator cable into the device that tells it you have a Smart Alternator, independent of whether that cable has current in it, or do I misunderstand where that cable gets attached at its end nearest the vehicle's engine?
It is my presumption that you hook this cable into some 12V outlet that is energized only when the engine is cranked, no?
TIA
TIA
