KevinC_63559
Hi guys...
My current little project is 12V, with (2) Fiunie 100amps (I suspect no-name, no-warranty that would be enforceable, but they were cheap on Amazon (under $200 delivered) and have bluetooth BMSes - so good for my starter project).
As I wait for my Victron based components to be delivered, I'm thinking about phase 2 of my project, which will be 48V base and probably 5-10 times as much of an investment. With that in mind, and due to the excellent support I'm getting at CurrentConnected, I'm considering their SOK 48V battery packages. One of the products features is the ability to get to and replace any component that fails with little more than a screwdriver and wrench. My question is: How much is that worth? What would likely fail? If the BMS fails, and replacement BMSes are available (likely, given the supplier rep), I could see huge value in that. If a battery cell fails (I'm presuming 16 cells inside the case), is it cool to just replace one? That seems to violate my understanding that all batteries in a series need to be from the same manufacturer and of similar age. So if one cells dies, since they are all in series, wouldn't I have to replace them all? Which is the most likely scenario?
Thanks in advance,
Kevin
Thanks in advance,
Kevin
