Hi folks,
Curious if anyone has purchased the SOK Marine 100Ah LiFePo4 battery?
Could you post pictures of the internal BMS & Battery connections?
I know Will did a tear down on the 206Ah battery, but I have yet to see a tear down on this newer 100Ah battery. Because of space limitations, I need the dimensions of the 100Ah...
Also, what is the deal with the voltages that are listed on the datasheet? It says: "4.Flexible - Works in 12, 24 or 48V configurations,or connect in Parallel for Larger Capacity."
Why is 36V missing on the voltage configuration? Seems weird that I could not wire 3 in series but 4 in series is ok?
Thanks,
-J
SOK Lithium Iron Phosphate 12V 100Ah Battery,Marine Grade | SOK Battery USA
In stock, ready to ship.SOK Lithium Iron Phosphate 12V 100Ah Battery,Marine Grade
www.us.sokbattery.com
Thanks,
-J
