garetwo
Well, my roller coaster ride continues. First, just to head off the “never do that” stuff, it has already been done, I know better now, but it was not me to begin with. Also, since trying to help a friend AND joining this forum the 16 JITA 12.8vdc 300ah batteries arranged 4S4P will now have a Victron 500amp shunt on each group of four and an equalizer across each group of four – none are installed yet, but THANKS!!! To all the input that has moved us to this point.
Now, the story and the question. He just told me he found batteries down to 8vdc. Disregarding why this takes place (the equalizers will help now) what does the battery’s internal BMS actually do?
What does this mean?: DISCHARGE PROTECTION VOLTAGE 10.0-10.8. Is it just to set inverters to stop using batteries if they see whatever we set them to or is the internal BMS supposed to somehow stop allowing the battery to discharge?
There was a wild swing in voltages across the individual batteries. I am going to find out what equalizer he purchased. I can see you cannot have a single battery drop out in a group in series, but perhaps he can get an alarm when a single battery hits 10.8 VDC so he can at least open the disconnect for that set of batteries. Th=is brings up the second question, “Can a bank of batteries in series be somehow automatically dropped out if one battery gets too low”?
One more, is there a low-end voltage point where a LifePO4 battery is damaged? My friend told me he has seen them drop to zero and not have a problem.
