Have 10 SOK server rack batteries. Recently setup to get pack level data. See circled data. Does the battery pack adjust the capacity overtime? Instead of reporting charge state greater than 100%. Shouldn’t it adjust the battery capacity?
It's my understanding SA is pulling the capacity that is set in the BMS. You would need to adjust the BMS parameters if they are only 100ah cells.
Also your cells look like they are in need of a good balance. 3.339-3.445 is quite a spread.
