717micah
I’m new to off-grid solar systems and need help determining if 1) all the components I currently have are compatible for building my electric system 2) what would be the best solar panel array to start with for around $1000 that would also leave potential for adding more panels and batteries to the system in the future, bearing in mind the panels will be mounted on top of a Skoolie and 3) need advice on the safest and most efficient way to set it all up… Any assistance is greatly appreciated ![Slightly smiling face :slight_smile: 🙂](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
2 - Redodo 12V 200Ah PLUS Lithium LiFePO4 Batteries with Max 2560W Power Output & 200A BMS Protection
SunGoldPower Hybrid Solar Inverter Charger 3000W DC 24V Pure Sine Wave Inverter / 80A MPPT Solar Charger / 40A AC Battery Charger
Westinghouse 4500 Peak Watt / 3900 Running Watt Dual Fuel Portable Inverter Generator
![3000 watt 24 volt pure sine wave inverter 3000 watt 24 volt pure sine wave inverter](https://m.media-amazon.com/images/S/aplus-media-library-service-media/5915421e-b051-4faf-8084-74706997c967.__CR0,0,970,600_PT0_SX970_V1___.jpg)
