JeromeP
I’m debating between using the Anker F3800 power station (3,840WH/6000, 240V, and adding 1 Eg4-LL storage battery or an Eg4 6000XP inverter while adding 1 or 2 Eg4 server rack batteries.
The Anker power station has 1 major drawback for me being the 240v outlet cannot be used while charging with a 48v solar battery charger. The price for this system currently is $4500 which includes one expansion battery on Shop Solar. I’m uncertain if there is a work around to this 240v issue.
The second system, EG4 6K XP Off-Grid Inverter | 8,000W PV Input | 6,000W Output | 48V 120/240V Split Phase with two EG4®-LL-S 48V / 100AH Lithium Battery | 5.12kWh also for $4500 on Shop Solar. I know this is a no brainer but this inverter only accepts a 240v gas generator for the ac charging, at least to my understanding, correct me if I’m wrong.
I have no solar array but will have way down the road when money permits, retired and on fixed income.
I have virtually no solar experience but have watched many solar energy videos including many of Will Prowse videos. If I go with the Eg4 system, I’m sure with your guidance, with the help of my son which he had built a small solar system from scratch and I understand Shop Solar has excellent customer service, I can make this happen having a long term running solar system for when the grid is down for the long haul.
I know there is a 30% federal energy tax credit now; however, I don’t qualify since I don’t have any taxable income. Otherwise, I would go bigger.
House is 1100 sq ft
My current situation:
Live alone
I run an outdoor wood boiler for heat, very rarely use the a/c
Wattage usage during the day: on average is 10k
Usage consists of some led lighting, 700 watt fridge, medium size upright freezer, a few other light duty consumptions.
240 volts for a ¾ hp well pump, 4500 watt water heater, I will need the water warm in the mornings for my 10 minute shower and to wash dishes The a/c is not that important to me.
Currently have a Westinghouse 3500 watt dual fuel inverter generator.
Nearly full 500 gal lp tank for the last few years, I use my indoor wood stove on the shoulder heating months for heat.
Appreciate your help!
House is 1100 sq ft
Live alone
