Solar controller in error when exceeding 100v DC on PV array. Max Voc controller: 145v
subjero
Belgium
Hi guys,
I know it is not the best solar charge controller, but i have a jing/jng jn-mppt-bl controller and the controller is in error every time the PV voltage is over 100vdc.
PV array open circuit voltage range should be: 80-145V (48V battery system) according to page 8 in the manual:
I want to connect 3 panels in serie, but when i do the voltage is +-110v dc and the controller is shutoff.
When i connect 2 in series the voltage is +-80v dc (and lower when charging) and all is working fine.
Do i have a faulty controller, do i need to make a setting change? I am lost here.
Thanks and kind regards,
Hi guys,
Either faulty or it can actually only support around 100V? Is it one of these?
https://www.enfsolar.com/pv/charge-controller-datasheet/2825
