Captmaddog
- Jun 29, 2022
- 3
I have a 2013 Itasca Meridian 34B motor-home that I am wanting to use solar power for dry camping. It has a 6 battery (group 31 AGM) bank that runs everything but the air conditioning units. Almost everything on this motor-home is electric. Fridge is residential electric fridge. Only gas is the stove and furnace. I can run everything on 30 amp plug in including 1 A/C. My question is how much solar panels would I need to keep the batteries charge and would I go directly into the Inverter/Charger or connect up directly to the batteries with an additional controller? Any help is appreciated as I am completely new to solar. Also Probably should say I have a 2800 watt inverter installed and an automatic dual battery charge with the inverter.
