So bare with me while I explain... I'm relatively new at this so forgive any newbie mistakes. I am purchasing a cruising sailboat that is outfitted with a flooded lead acid house battery system. I will be changing this out for lithium at some point in the future. The boat is also wired for a genset but does not have one installed. There is a dedicated enclosure for the genset as well. Because the boat has a limited amount of storage, this locker is currently being used for other items. The idea of having a self contained solar "generator" like a Titan or Bluetti is a good one because I can easily move it in and out of this locker and potentially have room for other items. I realize I could diy my own self-contained system that is portable, but I'd rather not do that at this point. I would like to have enough wattage to run a watermaker or one of the AC units off this battery "genset", but even the Titan may not do it. And before you ask, I don't immediately have the specs for the AC unit or watermaker as I have not closed the sale on the boat yet. So, I'm thinking that 2 bluetti 2000 units, for example, would be able to handle the load if they were paralleled. Then I would have the convenience of the form factor to remove one off the boat to run a pellet grill or campsite, etc.
