derekisastro
- Jan 27, 2021
- 77
Hi all,
I had an interesting experiment over the last weekend with 2 of my 240W panels.
They are side by side and I was measuring their individual outputs as well as their combined parallel and series outputs. I got a result I could not explain (I am sure I am missing something?).
Individually, due to partial shading of 1 panel, I got 33.3V @ 7.05 amp (230W) for the non-shaded panel and 33.4V @ 0.32 (10W) amp for the partially shaded panel.
In parallel, I got 33.3V @ 7.3 amps. About 240W, makes sense.
In series, I got 66.6V @ about 7amps ... about 460W ... this doe NOT make sense to me. This was all measured with my DC clamp multimeter, either short-circuiting or measuring the output at the cabling attached directly to the panels. What am I missing? When connected to a charge controller, in series, is this when I will see the amperage/shading from the other panel affect the output?
I was assuming that with a saded panel or different shading on each of the panels that putting them in parallel would be best for output but my testing suggests the opposite ... right?
