JWLV
- May 27, 2020
- 550
I have 6 240W panels wired in 3S2P. Each panel's VoC is 37.6 and Pmax Voltage is 30.3. The panels are laid flat on the ground in my backyard.
When I disconnect the Growatt charge controller/inverter and measure the solar panels, it measures around 95V according to my multimeter. This seems to be correct, given that the VoC is 37.6 for each panel and it's about 100F right now. Once connected to the Growatt, the voltage drop to around 63V as reported by the dashboard page from Growatt.
This doesn't seem right. Right now it's about 11:25AM, the sun is almost directly overhead and the solar panels are getting full sun with no shading or obstructions, and yet the Growatt is reporting 63.4V.
Also, the maximum charge rate I've been getting over the past several weeks has been ~ 950W, usually right around 12 noon. It's never gone over 1000W. This would seem to be consistent with the voltage at 63V (2 panels in series) and not 95V (3 panels in series).
Any ideas as to what is wrong? Is one panel bad? How could I troubleshoot it to find out which one?
